fixed: AIDA64 Extreme does not display cpu +5V and +12V (Asus H110I-CM-AA)
sid
On 2017. 06. 25. at 8:49 AM, sid said:
Hi Fiery,
i humbly request you to provide a patch for ASUS-H110i-cm-aa motherboard to read +5v and +12v. i can pay you for the software.its a urgent requirement.
The mentioned new AIDA64 beta update is available for download at:
Let me know how it works ;)
Hi Fiery,
It works fine,im getting all the sensor values. thank you very much for your effort.
Now, i wish to buy it, can you please send me a quote for AIDA64 Extreme to siddu3868@gmail.com.
  • 3 years later...
36 minutes ago, Harith Zainal said:
Hi, may i ask, what kind of power supply you used to power up the 6 pin atx at the motherboard asus h110i-cm-aa?
It appears to be a 4-pin CPU, not a 6-pin(generally reserved only for PCIE cards or certain motherboards for PCIE slot power boost).
Any power supply will be able to work as long as the wattage is high enough. Either the PSU will have an 8-pin CPU power that splits into a 4+4-pin, or the solid 8-pin should fit with the extra 4-pins hanging over the outside.
