scomcomputers Posted September 1, 2017 Report Share Posted September 1, 2017 Hello, i use aida64 engineer new beta version ,my mobo Asus Prime x370 Pro! Aida not show the water pump rpm, the hwinfo show this....please fix it... Thank you! Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 2, 2017 Report Share Posted September 2, 2017 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
scomcomputers Posted September 3, 2017 Author Report Share Posted September 3, 2017 Ok.Thanks! isasensordump.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 8, 2017 Report Share Posted September 8, 2017 On 2017. 09. 03. at 6:42 AM, scomcomputers said: Ok.Thanks! isasensordump.txt Thank you for the data. Please upgrade to the latest beta version of AIDA64 Engineer available at: https://www.aida64.com/downloads/latesta64eebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works 1 Quote Link to comment Share on other sites More sharing options...
scomcomputers Posted September 8, 2017 Author Report Share Posted September 8, 2017 Thank You again... But i send is back yesterday Asus mobo,i testing now new mobo from Asrock. Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 8, 2017 Report Share Posted September 8, 2017 24 minutes ago, scomcomputers said: Thank You again... But i send is back yesterday Asus mobo,i testing now new mobo from Asrock. No problem As always, let us know if you find any issues about your new ASRock mobo as well Quote Link to comment Share on other sites More sharing options...
