AIDA64 Discussion Forum
tistou77
Water In sensor (Asus Rampage VI)
Hello
In the latest versions, the Water IN and OUT sensors have been integrated, very good
These sensors are not translated yet, I looked in the language file,
and the modification works
On the other hand would it be possible to put the In and Out with the option "Extented Labels"
If like me, we have only one probe, the In is not obligatory
Thanks
Share this post
Link to post
6 minutes ago, tistou77 said:
Hello
These sensors are not translated yet, I looked in the language file, but the changes do not work
Thanks
The French language module will be updated in the next AIDA64 beta build.
As far as I can tell, you cannot avoid putting more and more pressure on us about implementing the feature of renaming labels on the Computer / Sensor page ;);)  That would solve many of your existing issues about sensor labels I guess.  We'll jump on it now, it's already too much pressure :D
Share this post
Link to post
I modified the language file, it's good (I had edited my post)
Ok, I thought the option "Extented Labels" was to show / hide this kind of information :D
Share this post
Link to post
No, it's just to let you find from which source a certain sensor reading comes from.
Share this post
Link to post
Here's the first AIDA64 beta where you can rename labels on the Computer / Sensor page.  Right now it only works if you click on the label to edit it in-place.  So there's no right-click context menu or main menu item to perform the renaming.
Let me know how it works ;)  Please note that if you want to revert back to the default label, just clear the label (empty string) and press Enter.
Also note that we've had to rewrite the whole code behind the Sensor page in order to implement the label renaming feature, so the order of the readings could be slightly different than previously.  And also there's a slim chance that we've left minor bugs in there -- which I'm sure you'll catch ;)
Share this post
Link to post
Thanks so very much for your great work ;)
I test that when I go home
I will look for the order of the "probes" too
PS: tested on my laptop, it seems to work but very few probes
Share this post
Link to post
So I tested and it works, great :wub:
I noticed some small anomalies
1) For the French translation, Water In is translated as Eau dans, while it is Eau entrée (
or something like that)
2) In the voltage section, some voltages have been moved, but nothing serious, just the probes that are a little mixed (Before / After)
Before.PNG.c00a398ffd277e3df5abf58150a32fde.PNG   After.PNG.1f414f0bbeb519d8f74c03cefc007861.PNG
3) And I tested to rename the name of a section (Cooling Fans for example)
It works but it's not registered, and at the next launch, it's the default name
Thanks so much for your great work :)
PS: the name change is not reported in the System Stability Test?
Share this post
Link to post
1 hour ago, tistou77 said:
1) For the French translation, Water In is translated as Eau dans, while it is Eau entrée (or something like that)
1) Fixed it, thank you.
2) We'll bump VBAT Battery voltage down a line to make it look slightly better.
3) The groups (sections) cannot be renamed permanently.
4) System Stability Test uses a separate sensor module, so the changes you apply to the Computer / Sensor page will not affect the System Stability Test.
Thank you for your feedback.  Please keep 'em comin' ;)
Share this post
Link to post
1) You're welcome
2) ok ;) For the temperatures, it's very good
Maybe as for temperatures, "grouped" voltages (with the same icons) like this may be
CPU Core, VID, CPU Cache, VCCIN, VCCIO, VCCSA, +3.3v, etc... , VBAT, DIMM,  GPU Core
3) Ok thanks
4) Ok
Thanks so much ;)
Share this post
Link to post
Grouping cannot be 100% consistent about icons, because for example, on systems featuring an Intel iGPU the CPU GT Cores temperature will have a different icon :)
Share this post
Link to post
Hello
Ok, and for the CPU cache, etc ... it will not be better than grouped with the CPU Core, CPU VID ?
Like this (t
hat the "CPU" voltages are "grouped")
Thanks
Share this post
Link to post
On ‎9‎/‎19‎/‎2018 at 1:30 PM, tistou77 said:
Hello
Like this (t
Thanks
We'll try to improve on that.  It's not easy, since there're hundreds of sensor readings, coming from various sources (like CPU, chipset, onboard devices, HDD, SSD, video card(s), etc).  You can only see a few of them, but the capabilities of AIDA64 is much wider than what you can experience on one system.  Maybe the best way would be to enable re-arranging items on the Sensor page? ;)
Share this post
Link to post
Yes I doubt that with the number of components, the sensors are very numerous
Indeed, "re-arranging items" will be a good idea, a drag & drop ?
Thanks for your great work
Share this post
Link to post
We're already working on enabling drag & drop ;) Stay tuned........
Share this post
Link to post
On ‎9‎/‎25‎/‎2018 at 2:54 PM, tistou77 said:
Ok thanks, good news :)
Well... It's not quite as easy as I've expected :)  As long as you move the items inside the same group -- e.g. you move CPU temperature inside the Termpeatures group one line up or down -- it works great.  But, when you move an item into another group, things could get messy.  Not to mention a potential scenario when you would like to rename a group to e.g. CPU, and move all CPU related items into that group.  Also, it would complicate things even more if you wanted to remove (or hide) an item, and especially when you want to remove (or hide) a group or add a new group.  The potential need to change the grouping logic is the most challenging task to accomplish by simple drag&drop and context menu actions...  What do you think?
Share this post
Link to post
So the best I think and to avoid too much problem
- Limit the movement in the same group (temperature, voltages, etc ...) if too complicated to move to another group
- Hide an item (temperature, voltage) with the right click
- Rename a group
To add a group and move items in this group, it seems complicated ?
After to avoid adding groups, just create the groups that are needed
Watercooling group for pumps, flowmeter, etc ...
For fans, there is already a group, the same for temperatures and voltages
Share this post
Link to post
On ‎10‎/‎31‎/‎2018 at 6:40 PM, tistou77 said:
Hello
it's slightly progressing or not yet ?
Thanks
It's on hold right now.  We'll continue to work on it in December or January.  We're currently very busy with other issues :(
Share this post
Link to post
Ok thanks ;)
Share this post
Link to post
On ‎1‎/‎3‎/‎2019 at 1:38 PM, tistou77 said:
Hello Fiery, happy New Year
You started working on it ?
Thanks
Happy New Year!  Yes, already working on it.  It's quite a head-scratcher though...
Share this post
Link to post
Loading...
