fixed: AIDA64 Extreme random freezes (Asus Maximus XI Extreme + Asus ROG Ryujin 360)
Koithim
Hey there,
I recently upgraded my pc, i changed 3 things:
MB: Maximus XI Extreme
CPU: 9900k
Cooler: Ryujin 360.
Since then aida64 takes a very long time to start, become randomly unresponsive for random amount of time, sensor panel too. Aida64 never crash, it just become unresponsive randomly for a random time.
I uninstalled Aida, did registry cleaning, rebooted, re-installed Aida and same thing is happening.
Any help would be appreciated, thank you.
Koithim
On ‎11‎/‎24‎/‎2018 at 3:28 AM, Koithim said:
Hey there,
CPU: 9900k
Cooler: Ryujin 360.
Koithim
Do you already have a configuration file called AIDA64.INI in your AIDA64 installation folder?
While looking for a fix, I found this old post where Fiery says:
"It seems on some configurations reading EC (Embedded Controller) registers cause high DPC latency.  The only "solution" we've found so far is to disable EC readout by disabling the following options on the page AIDA64 / main menu / File / Preferences / Stability:
Embedded Controller (EC) support
Embedded Controller (EC) bank switching
After altering those options, make sure to restart AIDA64 to apply the changes.  However, by disabling those, you will lose a set of sensor readings, e.g. PCH temperature, T_Sensor1 temperature, WATER_IN temperature, WATER_OUT temperature, Water Pump fan, Water Flow fan, VCC Sustain voltage, CPU PLL voltage, VCCMP voltage."
So, I disabled Embedded Controller (EC) support and the stutter is gone. Also, Aida's CPU usage went from 10-15% to 2-5%
Temp sensors for PHC, VRM and an external sensor I have connected to the MB disappeared, but at least I have everything else and no stutter... Till there is a better fix, it will have to do...
Yes, I'm afraid on some Asus systems that's the only solution when the stutter comes up.  Strangely, it doesn't affect too many Asus systems, so it's not like it comes up on all Maximus XI Hero motherboards or such.  There must be something unique in your system configuration that makes the EC work different to other systems based on the same motherboard.
16 hours ago, Koithim said:
So far so good.  Ryujin 360 was the culprit.
Cheers!
K
Awesome!  Can you please enable the storage device again, and create an USB Dump for us?  That way we can add the Ryujin 360 storage device to the list of USB devices that are not scanned as a USB storage device for HDD SMART readings.
You can create such dump by right-clicking on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
11 hours ago, Koithim said:
Here are the file(s).  I also uploaded the HDD dump, since that is the dump that led me to the problem by freezing a long time on: [ HDD: AsusTek ROG RYUJIN USB Device ].
As soon as re-enabled the storage device the problem re-occured right away.
Cheers!
K
usbdump.txt
hddsptidump.txt
Thank you for the data.  Make sure to upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works ;)
