AIDA64 Discussion Forum
Brynhildr Arai
AIDA64 Engineer cannot read motherboard fan speed (Asus Z10PE-D16 WS)
I am using the latest AIDA64 Engineer 5.99.4900.
My motherboard model is ASUS Z10PE-D16 WS,the sensor type is shown as Nuvoton NCT6779D/5535D (ISA 290h),this is correct, but the fan speed cannot be read and the motherboard temperature and CPU temperature display errors(In the BIOS, the temperature is correct and the fan speed is displayed normally).
Specific as shown.
2018.12.21_004.pngIMG_20181221_063932516.thumb.jpg.06bbc4dac12651b4306a960b18b74b69.jpgIMG_20181221_063948982.thumb.jpg.1f691264573108c595ba82fe4ed399f3.jpgIMG_20181221_064011193.thumb.jpg.5ad2a3542750f56ddc56dbc129fb453f.jpg
Share this post
Link to post
Specific as shown.
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Also, it would be very useful if we can have a reference list of sensor readings.  If possible, please send us a photo that shows all temperature, voltage and fan speed readings in the UEFI Setup (BIOS Setup).
Thank you in advance!
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Similar Content
    • By f2407731
      Hi guys don't know if this is the right section where to post my problem but i'll try
      I have a server that few months ago has started to gave me the attached error on the event viewer under te system registry(event error.PNG); the error says "The FinalWire AIDA64 Kernel Driver service failed to start for the following error : The driver loading has been blocked"
      the problem is as you can see on the program.PNG image i don't have AIDA64 installed on this server.
      i've tried to look for the C:\program folder ; the services; on the regedit ; on the task scheduler and on the statup program but i haven't found it anywhere.
      Thanks in advice for the help
    • By KushRajput
      Hey there,
      I recently purchased asus vivobook s15 s510un it comes with i7 8550u, 8gb ddr4 ram, 1tb hdd and mx150.
      It runs so slow because of hdd so i purchased a m.2 ssd and a 8gb ram stick, I know a guy who works in asus i called him and he upgraded my laptop, then I remember that stock thermals are not so impressive, so I said him to change my thermal paste with arctic mx4, so this guy wiped my old thermal paste just once actually he doesn't did a good job in wiping thermal and he applied mx4 in too much quantity from that time if i game(hitman or csgo) it reaches 99 celsius(it's not like it reaches at 99 and then it drops, continuous on 99 celsius during gaming and stress test) so I decided to run aida64 test and the test shows me overheating and cpu throttling(42%).
      So, If I will change my thermal paste again, this time with good wiping and apply mx4 in good quantity, then what you guy think will my laptop's overheating solve after that ?
      Note: When I did stress test in aida64 before changing thermal paste everything was working good no overheating and throttling.
      Here is a screenshots
    • By Orion8510
      Hi guys  New to the forum.
      I am using an old version of Aida64 extreme to overclock my i5 4690k on a cooler master hyper 212 evo ( im sure you this combination 1000 times already, lol sorry ).
      I follow what jayztwocents from you tube and others have told me to do so far. I slightly overclock my chip keep the frequency on fixed ( msi gaming 5 bios) , boot into windows, run intel burn test 10 times on standard, 1 times of very high and then run 1 hour of AIDA64 EXTREME system stability test.
      Am I doing this right or do I need to set my frequency from fixed to dynamic before the system stability test?
      The reason I ask is that when I ran IBT with the frequency on dynamic it kept cutting out, apparently it could be down to the test drawing to much power as it is on dynamic, but as the system stability test is just that I'm not sure what to set it on and what I can consider a pass.
      Any help and advice would be appreciated.
      Also any pointers to AIDA64 Extreme test guides too.
      Orion
    • By MFSAKA
      Recently I bought Presonus Firestudio 26x26 for my music studio
      its not new IEEE 1394 firewire audiointerface....and its kill my nervs!
      Few days its droppin out my sound (DAW, browser, AIMP etc.)
      Its NOT Legacy IEEE 1394 bugg - i try install thise old drivers - its not fix the issue.
      And accidentally i find out - IT AUDAS SENSORS PANEL IN DOCK make thosse glitches!
      I use portable version
      Try to install it regular.
      Sh*t's start buggin again!!!!
      I start system with out aida......take a half hours with out dropouts of sound - and first second when i run Aida - that crap start's again!
      Please fix the issue wuth Aida64 sensors buggin Presonus Firestudio 26x26 (Firewire 1394...maybe other hardware....PCI-e Card by Texas Instrument - confirmed by Presonus - its good)
    • By willdelarosa
      Hello my friends!   I configured aida64' OSD to show the information I want, as shown below:       I also configured aida64 to allow RivaTuner to take the data and display it inside the games. But, the problem is RivaTuner uses it's name / label. Is it possible to configure aida or Riva to display as the aida shows?       Thank you so much!
