GPU Less sensor, wrong index (P106 mining adapter issue)
xixou
Hi,
Could you keep index consistency about sensors?
If I use a GPU that has less sensors, the index is then not correct.
For instance, all GPU will have temp sensor and so for 3 GPU, that will be 1,2,3.
But if my GPU 2 (mining gtx 1060, P106-100), the other sensors for the GPU 3 will be indicated on GPU index 2.
Could you change this?
Attaching a picture that shows the issue.
nvidia dump:
------[ Versions ]------
Program Version : AIDA64 Extreme v5.97.4687 Beta
BenchDLL Version: 4.3.784-x64
Windows Version : Microsoft Windows 10 Pro 10.0.17763.195 (64-bit)
Motherboard ID      : 63-0100-000001-00101111-012115-Chipset$8A07AG0C_BIOS DATE: 06/15/18 13:35:52 VER: 05.0000B
Motherboard Model   : Gigabyte GA-X99-SOC Champion
Motherboard Chipset : Intel Wellsburg X99, Intel Haswell-EP
DMI MB Manufacturer : Gigabyte Technology Co., Ltd.
DMI MB Product      : X99-SOC Champion-CF
DMI MB Version      : Default string
DMI MB Serial       : Default string
DMI SYS Manufacturer: Gigabyte Technology Co., Ltd.
DMI SYS Product     : Default string
DMI SYS Version     : Default string
DMI SYS Serial      : Default string
DMI BIOS Version    : F23c
SMI Version      = Error Code 00
Mobo Version     = Error Code 00
CPU Temperature  = Error Code 00
CPU2 Temperature = Error Code 00
Mobo Temperature = Error Code 00
PSU Temperature  = Error Code 00
CPU Fan          = Error Code 00
System Fan       = Error Code 00
nForce Fan       = Error Code 00
Aux1 Fan         = Error Code 00
Aux2 Fan         = Error Code 00
Voltages         = Error Code 00
smbus
------[ GPIO @ isa 0500 ]------
0000  FF A1 7F 9F  FF 6E CB 88  00 00 00 00  FF 7F D3 AA
0010  00 00 00 00  00 00 00 00  00 00 04 00  00 00 00 00
0020  00 00 08 00  00 00 00 00  00 00 00 00  79 68 00 00
0030  FF F0 FF 23  F4 EF D7 1F  E3 9F FF FC  00 00 00 00
------[ 9 SMBuses detected ]------
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : 0580
Can Have SPD: No
Scan Type   : Full
  0000  00 00 00 04 00 00 00 00 00 24 25 15 02 25 12 18  .........$%..%..
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF24 FF25 FF15 FF02 FF25 FF12 FF18
  0010  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0030  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0050  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0070  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00A0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00D0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus #1 ]------
SMBus Type  : Intel SNB-E/IVB-E/HSW-E/BDW-E
SMBus Base  : PCI BFF D13 F00 R180 C0 SC0
Can Have SPD: No
Scan Type   : Full
------[ SMBus #2 ]------
SMBus Base  : PCI BFF D13 F00 R180 C0 SC1
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B02-D50 ]------
  0000  23 11 0C 02 84 19 00 08 00 60 00 03 01 03 00 00  #........`......
  0010  00 00 08 0D F4 1B 00 00 6C 6C 6C 11 08 74 20 08  ........lll..t .
  0020  00 05 70 03 00 A8 1E 2B 2B 00 78 00 14 3C 00 00  ..p....++.x..<..
  0030  00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36  .............6.6
  0040  16 36 16 36 00 00 16 36 16 36 16 36 16 36 00 00  .6.6...6.6.6.6..
  0070  00 00 00 00 00 EC B5 CE 00 00 00 00 E7 C2 1E 29  ...............)
  0080  11 01 20 00 00 00 00 00 00 00 00 00 00 00 00 00  .. .............
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 4A  ...............J
  0100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0140  04 CD 00 00 00 00 00 00 00 46 34 2D 32 34 30 30  .........F4-2400
  0150  43 31 35 2D 34 47 49 53 00 00 00 00 00 00 84 C8  C15-4GIS........
  0160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0180  0C 4A 0D 20 00 00 00 00 00 94 00 00 07 00 01 00  .J. ............
  0190  00 63 63 63 10 E9 4D 20 08 00 05 70 03 00 BA 1A  .ccc..M ...p....
  01A0  27 00 00 00 00 00 00 00 00 85 AE E7 88 88 88 D6  '...............
  01B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
------[ SMBus #3 ]------
SMBus Base  : PCI BFF D13 F00 R190 C0 SC0
Can Have SPD: No
Scan Type   : Full
------[ SMBus #4 ]------
SMBus Base  : PCI BFF D13 F00 R190 C0 SC1
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B04-D50 ]------
------[ SMBus #5 ]------
SMBus Base  : PCI BFF D16 F00 R180 C0 SC0
Can Have SPD: No
Scan Type   : Full
------[ SMBus #6 ]------
SMBus Base  : PCI BFF D16 F00 R180 C0 SC1
Can Have SPD: No
Scan Type   : Full
------[ SMBus #7 ]------
SMBus Base  : PCI BFF D16 F00 R190 C0 SC0
Can Have SPD: No
Scan Type   : Full
------[ SMBus #8 ]------
SMBus Base  : PCI BFF D16 F00 R190 C0 SC1
Can Have SPD: No
Scan Type   : Full
Dump took 59.5 sec
------[ Video Adapters ]------
nVIDIA GeForce GTX 1060 6GB (PG410) [10DE-1C03 / 10DE-11D7]
Zotac GeForce GTX 1060 3GB [10DE-1C02 / 19DA-2438]
------[ Video Driver ]------
nvapi.dll: 25.21.14.1694
C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_6992f55a2cc4b209\nvldumd.dll
------[ nVIDIA GPU #1 @ mem DE000000 ]------
GPU Clocks   = 1582 / 0 / 0 MHz
Memory Clock = 3802 MHz
GPU    Base Clock = 27000 kHz
Shader Base Clock = 27000 kHz
Memory Base Clock = 27000 kHz
nvidia-000000 = 136000A1  [GP106]
nvidia-001538 = 800003FF
nvidia-001704 = 8017FFE1
nvidia-001714 = C017FFE2
nvidia-00E114 = 0000021C
nvidia-00E118 = 0000021C
nvidia-00E11C = 00000001
nvidia-00E120 = 00000000
nvidia-00E728 = 00000000
nvidia-00E820 = 02020015
nvidia-00E8A0 = 0200001A
nvidia-020008 = 00003238
nvidia-020014 = 023101B6
nvidia-0200C4 = 000000D8
nvidia-0200C8 = 00000000
nvidia-0200D8 = 010000D8
nvidia-0200DC = 00000000
nvidia-020340 = 000000A0
nvidia-020344 = 0000006D
nvidia-020348 = 000000A0
nvidia-020400 = 00000043
nvidia-021000 = C0040000
nvidia-0214A8 = BADF510C
nvidia-022400 = 00000000
nvidia-022430 = 00000002
nvidia-022434 = 00000005
nvidia-022438 = 00000003
nvidia-02243C = 00000003
nvidia-022440 = 00000004
nvidia-088000 = 1C0710DE  [GP106]
nvidia-08A000 = 10F110DE
nvidia-100714 = 00001616
nvidia-101000 = 00400080
nvidia-10100C = 82003000
nvidia-120070 = 00000001
nvidia-120074 = 00000003
nvidia-120078 = 00000002
nvidia-122634 = 00000000
nvidia-300000 = EB79AA55
nvidia-310000 = 06AC63AF
nvidia-700000 = 00000000
nvidia-7E0000 = 00000000
------[ nVIDIA GPU #1 / ForceWare Properties ]------
Memory Type             = 8 (GDDR5)
Memory Vendor           = 6 (Hynix)
Memory Bank Count       = 1
Memory Bus Width        = 192-bit
GPU / MC / VE / BI Load = 100 / 25 / 0 / 1
VPE Count               = 0
Shader Pipe Count       = 2
Shader SubPipe Count    = 9
Total SP Count          = <unknown>
Total TPC Count         = 0
Total SM Count          = <unknown>
Core Count              = 1152
ROP Count               = 48
Partition Count         = 3 (mask: 00000007)
Fan RPM                 = 2163 RPM
Fan Duty Cycle          = 60 %
Core Voltage            = <unknown>
Core Rail Voltage       = 862500 uV
Current Pstate          = 2
PerfCap Reason          = 16 (Utilization)
Ventura State           = 0 (unsupported)
Physical Frame Buffer Size = 3145536 KB
Virtual  Frame Buffer Size = 3145728 KB
Total / Free Video Memory  = <unknown>
------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------
Perf. Levels   = 4
Active Profile = 2
curr-core/shader/mem-0 = 607 MHz / 0 MHz / 405 MHz
curr-core/shader/mem-1 = 569 MHz / 0 MHz / 810 MHz
curr-core/shader/mem-2 = 645 MHz / 0 MHz / 3802 MHz [Active]
curr-core/shader/mem-3 = 645 MHz / 0 MHz / 4004 MHz
orig-core/shader/mem-0 = 607 MHz / 0 MHz / 405 MHz
orig-core/shader/mem-1 = 569 MHz / 0 MHz / 810 MHz
orig-core/shader/mem-2 = 645 MHz / 0 MHz / 3802 MHz [Active]
orig-core/shader/mem-3 = 645 MHz / 0 MHz / 4004 MHz
------[ nVIDIA GPU #1 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
Active Profile = 255
curr-core/mem-0 = 1607 MHz / 3802 MHz
orig-core/boost/mem-0 = 1582 MHz / 1797 MHz / 4004 MHz
------[ nVIDIA GPU #2 @ mem DC000000 ]------
GPU Clocks   = 1860 / 0 / 0 MHz
nvidia-001704 = 800BFFE1
nvidia-001714 = C00BFFE2
nvidia-00E8A0 = 02000010
nvidia-020008 = 000033EA
nvidia-020344 = 00000055
nvidia-020400 = 0000004F
nvidia-088000 = 1C0210DE  [GP106]
nvidia-10100C = 02013000
nvidia-300000 = EB78AA55
nvidia-310000 = CC3F5C09
------[ nVIDIA GPU #2 / ForceWare Properties ]------
Memory Vendor           = 1 (Samsung)
GPU / MC / VE / BI Load = 100 / 100 / 0 / 2
VPE Count               = 0
Shader SubPipe Count    = 10
Total TPC Count         = 0
Core Count              = 1280
ROP Count               = 48
Fan RPM                 = 1409 RPM
Core Rail Voltage       = 1043750 uV
Current Pstate          = 2
PerfCap Reason          = 4 (Reliability Voltage)
Physical Frame Buffer Size = 6291136 KB
Virtual  Frame Buffer Size = 6291456 KB
Total / Free Video Memory  = 6291456 KB / 2842796 KB
------[ nVIDIA GPU #2 / ForceWare Clocks (old) ]------
Perf. Levels   = 4
Active Profile = 2
curr-core/shader/mem-2 = 569 MHz / 0 MHz / 3802 MHz [Active]
curr-core/shader/mem-3 = 569 MHz / 0 MHz / 4004 MHz
orig-core/shader/mem-2 = 569 MHz / 0 MHz / 3802 MHz [Active]
orig-core/shader/mem-3 = 569 MHz / 0 MHz / 4004 MHz
------[ nVIDIA GPU #2 / ForceWare Clocks (new) ]------
Perf. Levels   = 1
curr-core/mem-0 = 1860 MHz / 3802 MHz
orig-core/boost/mem-0 = 1506 MHz / 1708 MHz / 4004 MHz
------[ nVIDIA GPU #3 @ mem DA000000 ]------
GPU Clocks   = 0 / 0 / 0 MHz
Memory Clock = 0 MHz
nvidia-001704 = 8017FFC1
nvidia-001714 = C017FFC2
nvidia-00E8A0 = 02000012
nvidia-020008 = 0000319B
nvidia-020344 = 00000077
nvidia-020400 = 0000003E
nvidia-088000 = 1C0310DE  [GP106]
nvidia-100714 = 00001717
nvidia-310000 = 6A0B6E6A
nvidia-7E0000 = 0000BEEF
------[ nVIDIA GPU #3 / ForceWare Properties ]------
Memory Type             = <unknown>
Memory Vendor           = <unknown>
Memory Bank Count       = <unknown>
Memory Bus Width        = <unknown>
GPU / MC / VE / BI Load = <unknown>
VPE Count               = <unknown>
Shader Pipe Count       = <unknown>
Shader SubPipe Count    = <unknown>
Total TPC Count         = <unknown>
Core Count              = <unknown>
ROP Count               = <unknown>
Partition Count         = <unknown>
Fan RPM                 = <unknown>
Fan Duty Cycle          = <unknown>
Core Rail Voltage       = <unknown>
Current Pstate          = <unknown>
PerfCap Reason          = <unknown>
Physical Frame Buffer Size = <unknown>
Virtual  Frame Buffer Size = <unknown>
------[ nVIDIA GPU #1 / BIOS Info ]------
BIOS Version   = 86.06.58.00.21
Signon Message = GV-NP106D5-6G/FX0/061B
Bootup Core Clock   =    0 MHz
Bootup Shader Clock = 1006739 MHz
Bootup Mem Clock    = 117901 MHz
Ref. Clock 4000 =      0 kHz =   0 MHz *4
Ref. Clock 4008 =      0 kHz =   0 MHz *4 [Memory]
Ref. Clock 4010 =      0 kHz =   0 MHz *4
Ref. Clock 4018 =      0 kHz =   0 MHz *4
Ref. Clock 4020 =      0 kHz =   0 MHz *4 [Shader]
Ref. Clock 4028 =      0 kHz =   0 MHz *4 [GPU]
Ref. Clock 4030 =      0 kHz =   0 MHz *4
Ref. Clock 4038 =      0 kHz =   0 MHz *4
Diode Gain Mul        = 0
Diode Gain Div        = 0
Diode Offset Mul      = 0
Diode Offset Div      = 0
Diode Offset Bin Mul  = 0
Diode Offset Bin Div  = 1
Temp Compensation Mul = 0
Temp Compensation Div = 1
Max Div               = 0
Measured Temp Threshold (Raw)   = 0
Measured Temp Threshold (Int)   = 0 Celsius
Measured Temp Threshold (Float) = 0 Celsius
BIOS Temp Threshold             = 125 Celsius
Measured Diode Temp (Raw)       = 0
Measured Diode Temp (Int)       = 0 Celsius
Measured Diode Temp (Float)     = 0 Celsius
Diode Temp by ForceWare         = 79 Celsius
------[ nVIDIA GPU #2 / BIOS Info ]------
BIOS Version   = 86.06.3C.00.60
Signon Message = GP106 PG410 SKU 20 VGA BIOS
Diode Gain Mul        = 0
Diode Gain Div        = 0
Max Div               = 0
Diode Temp by ForceWare         = 62 Celsius
------[ nVIDIA GPU #3 / BIOS Info ]------
BIOS Version   = 86.06.0E.00.81
Signon Message = NVIDIA GeForce GTX 1060 VGA BIOS  P14N:1066G0ED
Bootup Shader Clock = 654417 MHz
Bootup Mem Clock    = 572662 MHz
Diode Gain Mul        = 0
Diode Gain Div        = 0
Max Div               = 0
Diode Temp by ForceWare         = 0 Celsius
------[ NVAPI GPU Handles ]------
GPU Count = 2
GPU #1 = 00000200
GPU #2 = 00000300
------[ nVIDIA GPU #1 / Thermal Settings V2 ]------
Sensor Count = 1
Sensor #0 / Controller   = GPU Internal
Sensor #0 / Target       = GPU Core
Sensor #0 / Current Temp = 79 Celsius
------[ nVIDIA GPU #1 / Thermal Settings V1 ]------
Sensor Count = 1
------[ nVIDIA GPU #2 / Thermal Settings V2 ]------
Sensor Count = 1
Sensor #0 / Current Temp = 62 Celsius
------[ nVIDIA GPU #2 / Thermal Settings V1 ]------
Sensor Count = 1
On ‎1‎/‎5‎/‎2019 at 1:55 PM, xixou said:
Fiery, Could you support that sensor?
I don't think the sensors are assigned incorrectly across the cards.  What may be the problem is if AIDA64 uses a different indexing order for your 3 GPUs than other software or the physical order of your video cards.  AIDA64 uses the order that is dictated by the PCI device ordering on the PCI bus.
Could you add sensor support for that card?
Have you read my response?  The issue is not about supporting one or more of the video cards (BTW, they're already supported), but the way AIDA64 indexes and orders them.
On ‎1‎/‎30‎/‎2019 at 10:05 AM, xixou said:
Well, if you look at the attached debug pci list,
the giqabyte looks not supported.
In your dump above I can see the list of video adapters as:
It means at the time AIDA64 started up, it could detect 2 video adapters in your system.  "Video adapters" as a technical term in this case includes mining adapters and nVIDIA Tesla accelerators as well.  However, in case your mining card was sleeping while AIDA64 was starting up, it could well be invisible on the PCI bus and so not picked up by the GPU detection module of AIDA64.  You can try to enable Wake GPUs up at AIDA64 startup in AIDA64 / main menu / File / Preferences / Stability in order to make sure all video cards and mining adapters are "nudged" by AIDA64 at its startup before the actual GPU detection is performed.  Please let me know if it helps.
  • 3 weeks later...
ok I enabled the wake up below multi gpu, that was also enabled,
result is:
B01-D00-F00 [10DE-1C07] [1458-378A] [CC0302]: nVIDIA P106-100
B02-D00-F00 [10DE-1B81] [10DE-119D] [CC0300]: nVIDIA GeForce GTX 1070 Founders Edition (PG411) Video Adapter
B02-D00-F01 [10DE-10F0] [10DE-119D] [CC0403]: nVIDIA GP104 - High Definition Audio Controller
B03-D00-F00 [10DE-1C03] [10DE-11D7] [CC0300]: nVIDIA GeForce GTX 1060 6GB (PG410) Video Adapter
B03-D00-F01 [10DE-10F1] [10DE-11D7] [CC0403]: nVIDIA GP106 - High Definition Audio Controller
So in that case you cannot rely on the missing
Video Adapter
because it is absent: nVIDIA P106-100
result is:
Video Adapter
I'm not sure if I understand the current state of the issue, so please clarify: after enabling the GPU waking option, all your GPUs are picked up by the PCI device enumerator of AIDA64,  but you still don't have all 3 GPUs listed properly on the Display / GPU page of AIDA64?
  • 3 weeks later...
Well,  all 3 gpu are present but some sensor like TPD are missing.
I use aida64 5.97.4687 Beta
My best guess is that for some reason ForceWare decides to put one of your non-primary GPUs to sleep, and then fails to report any measurements for the sleeping GPU.
No because when I close aida64, load the gpu (mining) then re open aida64,
the sensors are still missing.
GPUZ properly shows the TPD sensor of that special mining card.
See below:
See below:
This is really puzzling...  The issue must be related to the kind of card you've got (that it's a mining adapter and not a video adapter).  We've ordered an Asus Mining-P106-6G board to try and replicate the issue here and dig down deeper.  I apologize for the delays in fixing this issue.  I'll update you in this topic once we've got the mining card.
  • 3 weeks later...
On ‎5‎/‎3‎/‎2019 at 6:41 PM, xixou said:
So?
Our P106 board arrived.  Apparently the standard nVIDIA GPU detection API (called NVAPI) doesn't support mining adapters.  It may be possible to poll the card using another nVIDIA API called NVML, but that API cannot be called from 32-bit applications, so we cannot support it at this time.
