AIDA64 cannot read data from Aquabus devices (Aquaero 5 XT + D5 Next + MPS)
Buelldozer32
Hello everyone,
After reading a lot of post I still didn't find a solution for my problem.
I have An Aquaero 5 XT with a D5 pump and a MPS sensor connect with Aquabus. I cannot get the MPS pressure nor the pump speed when they are connected on the Aquabus. If I connect them with USB, it works well and I have both datas in Aida64.
Does anyone have an idea to help me?
Regards
Florian
On 12/1/2019 at 11:35 PM, Buelldozer32 said:
Hello everyone,
Regards
Florian
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aqua Computer Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Please also let us know the approx. expected values for the readings at (or around) the time you've issued the dump.
13 hours ago, Buelldozer32 said:
Hello Fiery,
Thanks for your reply and sorry for the late message. And happy new your to all Aida64 team!
Here is the file you asked and the actual values. The pump and pressure sensor Aquabus too.
Thank you for the data.  The issue will be fixed in the next AIDA64 beta update.  I will post a message into this topic once the new beta build is available for download.  Till then, I hope you're having a Happy New Year too! ;)
  • 1 year later...
