Lasgol Posted February 3, 2021 Report Share Posted February 3, 2021 (edited) I have this issue as well. CPU: Ryzen 5 2600 GPU: AMD RX580 MOBO: MSI B450 Tomahawk Max AIDA64: 6.32.5631 Beta GPU Driver: 21.2.1 Windows 10 Home: 19042.746 With everything as above my computer froze after 5 hours. I subsequently disabled GPU monitoring and I have been freeze free for 12 hours. If I can make it 24 hours I will enable GPU monitoring and see what happens. Before the updates to software my computer could only manage about 45 minutes before freezing and a subsequent restart. Edit: My computer only managed 12 hours before it froze again. Better than 45 minutes but still not acceptable. Edited February 3, 2021 by Lasgol Update Quote Link to comment Share on other sites More sharing options...
gawwise Posted February 4, 2021 Report Share Posted February 4, 2021 On 2/2/2021 at 7:26 AM, SpajdrEX said: Greeting from AMD Vanguard team, could you please check if this issue also happens with 21.2.1 driver? and let us know the results? updated graphics driver to 21.2.1 for my rx vega 56 with aida64 running and it still crashed. if i dont run aida64 everything runs normally. i just cant monitor my system temps etc... Quote Link to comment Share on other sites More sharing options...
UZUMAKI28 Posted February 13, 2021 Report Share Posted February 13, 2021 still freezing and restarting Quote Link to comment Share on other sites More sharing options...
ProbablyAlex Posted February 24, 2021 Report Share Posted February 24, 2021 I'm also having this problem. Ryzen 5900x, Radeon 6900XT, Asus ROG Strix x570-f Everything is up to date, windows, drivers, BIOS, etc. I stopped running the Sensor Panel for about 2 weeks and had 0 crashes. I turned the sensor panel on today and couldn't get through 1 match in CoD MW before it crashed. I reviewed the Memory Dump files that were getting created and it definitely seems to be AMD driver related. Quote Link to comment Share on other sites More sharing options...
scraane Posted March 7, 2021 Report Share Posted March 7, 2021 Im having the same issue. Using latest Aida64 beta with radeon 21.2.3 with a RX 5500 TX. I mostly use the system for work and it happens when using Teams. Quote Link to comment Share on other sites More sharing options...
FrankieDedo Posted March 9, 2021 Report Share Posted March 9, 2021 Hi, having the same issue here (since more than year now, just traced back to AIDA64 today). I have changed everything except triple monitor setup and CPU. Now my system is this: CPU: Ryzen 7 2700X (latest chipset driver installed) GPU: ASUS ROG RX 5700 XT O8G (21.2.3 optional driver installed after DDU) MOBO: MSI X570 MPG GAMING PLUS PSU: 800W Seasonic Gold RAM: 32GB (4x8) Hyper-X Fury Black. Also happened with F4-3200C16D-32GTZRX (2x16GB G.Skill RAM, X version for Ryzen) and Patriot Viper Steel 2x16GB. All of them at both 3200MHz, with and without XMP enabled and at base frequency, without XMP. Samsung digital frame SPF-107H with various AIDA64 sensors. Previous config had a XFX Thicc III Ultra RX 5700 XT and an old Sapphire R9 270X for a while, Rog Strix B450-F mobo and the G.Skill RAM for Ryzen listed up here. PSU was a 750W ROG Thor. After changing EVERYTHING and fiddling with EVERYTHING a post somewhere told me to remove Argus Monitor in order to stop BSOD 116, i removed it and BSODs fairly diminished. Tried to install a similar fan control software (with GPU fan and temperature detection in it) and crashes became immediately more frequent. I figured that this could be a sensor polling issue or something like that, so i looked for interactions with AIDA64 and found here @ProbablyAlex's post that looked EXACTLY like my BlueScreenView situation. Now i have deactivated AIDA64 at Windows start and will see until sunday if something happens. After that, i'll install the beta (i was on stable until today) and see if BSODs will come back or not. I wanted to share this with you because, in my opinion, it's AMD's job to fix this, as it seems that their driver is extremely sensitive when it comes to read temp sensors. If two softwares reading gpu temp are worse than one, and removing all of them stops crashes, well... I'll send AMD some reports, from both the Adrenalin bug report tool and their online customer service and see if something happens. Also, are any of you using Argus Monitor or Rem0o's FanControl? Have you any crashes? Quote Link to comment Share on other sites More sharing options...
RWV Posted March 31, 2021 Report Share Posted March 31, 2021 Same issue: New Build all latest drivers except running 3003 on MB 5950X, XFX 6900, 2x16 ripjaw ram, win10 - 64, MP 400 SSD, ASUS dark hero Freezes or resets and reboots. Def associated with ADIA 64 and maybe ARGUS. Have loaded HWMonitor, CPUZ and GPZ but have turned those off on startup. Also seeing open temp readings on VRM - reading correct then goes off scale high - open and i see this in ADIA64 and HWM. Quote Link to comment Share on other sites More sharing options...
grzesj Posted April 10, 2021 Report Share Posted April 10, 2021 Hello. Same here. I`m running 5900x + GB 6800xt. I use sensor panel on my additional 7` LCD screen. Between 30mins - 1hr the system just freeezes, I need to hit power/reset button, and sometimes it has problems with booting up. Quote Link to comment Share on other sites More sharing options...
Grelot Posted April 10, 2021 Report Share Posted April 10, 2021 i have the same problem with a 5950x+6900xt reference.. PC hang with aida64 running on a 5'' screen after a couple hour.. Quote Link to comment Share on other sites More sharing options...
twiebie Posted April 16, 2021 Report Share Posted April 16, 2021 Any update on this? I have the same issue on my Ryzen 2600 and Vega 64. Quote Link to comment Share on other sites More sharing options...
Chris Swann Posted April 17, 2021 Report Share Posted April 17, 2021 Just upgraded my GPU from 2080 super to a 6900XT games now crash when using Aida64 with the 6900XT Quote Link to comment Share on other sites More sharing options...
Michel Beausoleil Posted April 22, 2021 Report Share Posted April 22, 2021 On 4/17/2021 at 6:08 PM, Chris Swann said: Just upgraded my GPU from 2080 super to a 6900XT games now crash when using Aida64 with the 6900XT amd and aid64 are looking into-it. 1 Quote Link to comment Share on other sites More sharing options...
twiebie Posted May 25, 2021 Report Share Posted May 25, 2021 On 4/22/2021 at 4:22 AM, Michel Beausoleil said: amd and aid64 are looking into-it. is there any update to this? Quote Link to comment Share on other sites More sharing options...
Michel Beausoleil Posted May 25, 2021 Report Share Posted May 25, 2021 since 6.33.5700 aid and amd 21.4.21 din't have a problem. but dint game more than 2h strait. Quote Link to comment Share on other sites More sharing options...
Chris Swann Posted May 27, 2021 Report Share Posted May 27, 2021 Update, I have the new AMD gpu driver installed and wanted to see if the sensor panel would work. It doesnt, as my system crashes while using excel. Quote Link to comment Share on other sites More sharing options...
trancie27 Posted May 31, 2021 Report Share Posted May 31, 2021 So, i tried beta 5752, Radeon driver 21.5.2, and still get this crash. is this actually being worked on? Are we going to see a fix at all? 1 Quote Link to comment Share on other sites More sharing options...
trancie27 Posted June 23, 2021 Report Share Posted June 23, 2021 I've been running Aida64 5700 and the new radeon driver 21.6.1 for 24 hours, monitoring gpu sensors, and it hasn't crashed, maybe this is the fix we have been waiting for Quote Link to comment Share on other sites More sharing options...
trancie27 Posted June 25, 2021 Report Share Posted June 25, 2021 Well, I THOUGHT the problem was fixed. Tried both latest stable and beta versions of Aida64. The problem persists. With how quiet the devs have been about this I have to assume there will not be a fix. Until I see otherwise I’ll be removing the software. No point in keeping something that breaks your system. Quote Link to comment Share on other sites More sharing options...
n0x1ous Posted June 25, 2021 Report Share Posted June 25, 2021 I have been following this topic as well. I have been troubleshooting 6900xt system crashes and freezes and it seems to be aida64. Was just about to turn it back on after Trancie27 post from wednesday but I guess I will leave it off. Very annoying. I have been using aida64 for years and this is the first time something like this has happened Quote Link to comment Share on other sites More sharing options...
trancie27 Posted June 27, 2021 Report Share Posted June 27, 2021 There appears to be a new beta out, released two days ago, there is nothing in the change log pertaining to anything AMD or Radeon related. I am still going to give it a go, I'll update in 24 hours 1 Quote Link to comment Share on other sites More sharing options...
trancie27 Posted June 28, 2021 Report Share Posted June 28, 2021 So I know I stated that I would post an update but I am going to be delayed. I live in the north west. We’re currently experiencing an apocalyptic heat wave of which I have never seen in my life. I can’t have my pc running and maintain survivable temperatures in my house. I’ll update as soon as I figure out a way to keep the heat levels down to a level which my AC can handle. Quote Link to comment Share on other sites More sharing options...
trancie27 Posted June 28, 2021 Report Share Posted June 28, 2021 I managed to run the pc long enough today. The latest beta has no fix for us. Still experiencing the same issue 1 Quote Link to comment Share on other sites More sharing options...
Elias_P Posted June 30, 2021 Report Share Posted June 30, 2021 I can also confirm. Still getting crashes when running AIDA with my 6800XT, same as it was with my previous Vega gpu. And it sucks that I paid for a software license to make use of the SensorPanel and be broken after so much time.. Quote Link to comment Share on other sites More sharing options...
twiebie Posted July 7, 2021 Report Share Posted July 7, 2021 I raised a ticket to the aida64 support team. Their answer to this issue is the following: Quote Hi, We really hope AMD is working on this issue as it is a driver related issue... Please keep following the topic you mentioned as we'll post there as soon as we'll have any news about this issue. Best Regards, Miklos Andrassy Sales Director FinalWire Ltd. Web: www.aida64.com Twitter: www.twitter.com/AIDA64_Official Facebook: http://www.facebook.com/AIDA64 Quote Link to comment Share on other sites More sharing options...
