boombastik Posted April 15 Report Share Posted April 15 Is this fixed with version AIDA64 v6.70? Quote Link to comment Share on other sites More sharing options...
Anthony Harvey Posted April 16 Report Share Posted April 16 21 hours ago, boombastik said: Is this fixed with version AIDA64 v6.70? i have re installed v6.70 this morning and im now testing. im 1 hour in without a system hang/freeze. iv gotten this far in the past though so il let you know how things go Quote Link to comment Share on other sites More sharing options...
Anthony Harvey Posted April 16 Report Share Posted April 16 44 minutes ago, Anthony Harvey said: i have re installed v6.70 this morning and im now testing. im 1 hour in without a system hang/freeze. iv gotten this far in the past though so il let you know how things go No fix, system hangs until manually restarted and amd driver corrupt to the point of needing to be completely removed and reinstalled without aid64 to enable system stability. really annoyed with this problem now. Its absolutely an aida64 issue. without aida64 installed the system is 100% stable and does not encounter any issues. the second you install aida64 and use the sensor panel the problems start. PLEASE PLEASE FIX THIS GOD DAMN ISSUE AND STOP BLAMING AMD Quote Link to comment Share on other sites More sharing options...
Silas83 Posted April 18 Report Share Posted April 18 Hello, i also had these crashes with 5800X+6900XT. I struggled a while with crashes after minutes or even seconds! I got a feeling to go to the BIOS and set the PCI slot where my GPU is located and set it from GEN4 to GEN3 and the crashes were gone for now... I have to observe it for longer period of time!!! Quote Link to comment Share on other sites More sharing options...
RaymondZGames Posted May 13 Report Share Posted May 13 On 4/18/2022 at 12:14 PM, Silas83 said: Hello, i also had these crashes with 5800X+6900XT. I struggled a while with crashes after minutes or even seconds! I got a feeling to go to the BIOS and set the PCI slot where my GPU is located and set it from GEN4 to GEN3 and the crashes were gone for now... I have to observe it for longer period of time!!! Any updates? Quote Link to comment Share on other sites More sharing options...
Matty Smith Posted June 4 Report Share Posted June 4 No updates to this? Quote Link to comment Share on other sites More sharing options...
