Tanmay Saha Posted May 14, 2021 Report Share Posted May 14, 2021 Hello, I am not sure you will be able to help me, but I have to ask; I have A-Data S599 SSDs and the latest firmware fixed some issues but, unfortunately, broke the temperature reporting. The temperature reported is twice the actual temperature, and, although it has no actual effect on anything, it is annoying. https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam So, my question is, is there any way to modify AIDA64 to cut the temperature being reported in half, so that the actual temperature is displayed? I only ask because A-Data, disappointingly, is apparently not interested in fixing the issue, as I have found from repeatedly emailing them. thanks alexsunny Quote Link to comment Share on other sites More sharing options...
Arctucas Posted May 16, 2021 Report Share Posted May 16, 2021 File>Preferences>Correction>New (add your device)>set Ratio to whatever makes the correct temperature appear. Quote Link to comment Share on other sites More sharing options...
