Hi everyone: how is this possible, or is it normal?
Well when i raise the resolution of the sensor pannel, without CPU last, it shows 10° more then the little resolution. I post some immages to explain the situation:
Case 1: Resolution 800x480 - CPU last 3% - CPU Temp Idle 43°
Case 2: Resolution 1600x2560 - CPU last 4% - CPU Temp Idle 51°
How is this possible? Or you think this is normal?
