Hey guys, I'm new here.
So basically, after checking many benchmarks here and on other forums, I've got curious and ran a benchmark of my PC and found out that my memory speeds are simply very low. They are even lower than some DDR3 systems. My memory is G.Skill F4-3200C16D-16GTZR. It's not a B-Die, but can it really be that bad anyway? XMP is enabled in BIOS and running at full 3200 speeds.
Any help would be appreciated. Thanks.
  • 2 months later...
Those are normal numbers for 3200mhz cl16 memory without being Overclocked and having timings tuned. You need to OC, I have same memory pretty much with an overclock to 4000mhz cl18 which isnt great by any means but it helped. my benchmarks are Read: 59,996  Write: 59,557 Copy: 60,081 Latency: 59.7 ns
I have T-Force Delta R 3200cl16 so pretty much same. If you want to Overclock check out discord channels
