CJ Smith Posted January 16, 2023 Posted January 16, 2023 Brand new user here - setting up a Gigabyte Z690 Gaming X DDR4, with a MSI MAG CoreLiquid 360P (no rgb). Everything is working nicely now that I am running in Admin all the time - except for the pump rpm. The pump is plugged into the recommended pump header on the motherboard. Both the BIOS and Libre Hardware Monitor show the same speed, near 4000RPM, which is comparable to what the radiator specs say the pump should run at. However, Aida64 reports the pump rpm as 10 - nowhere near 4000. Note that Aida64 sees this (correctly) as one of the fan headers on the board. Is there something specific needed to tell AIda64 to correctly show the readings from this pump speed sensor? Quote
