Dedicated Memory not displaying when both iGPU and dGPU are active
Hi,
Whenever I plug anything into the iGPU it seems to become the primary GPU on a system level. When this happens the sensor panel cannot detect the Dedicated Memory of the dGPU. I haven't found a way to change which GPU it reads from. It is not a driver issue as both the A770 and U770 use the exact same driver. It is also convenient using the iGPU for the Sensor panel display.
With nothing plugged into the iGPU
With a display plugged into the iGPU
Hi,
Originally when I posted this request looking for help it it was then moved to a bug report section.
Is this actually a bug or is it a case where there is no multi-gpu support?
  • 4 months later...
As of Version: 6.90.6517 beta (Aug 18, 2023) it mostly works. The only missing is the fans. For that I might just add some iGPU stats in its place.
Thank you!!
