DJTH Posted March 28, 2023 Share Posted March 28, 2023 CPU usage is reported higher than in previous version and cores are apearing and disapearing when at 0% In previous version the usage was normaly at 0% now at 7% Have I been seeing wrong values or is it something with this new version? I run the very latest Beta release of Windows 11. In previous version (I run the very latest!) the panel item stayed in place also when at 0% Both happened after the latest update when Aida64 had reloaded the sensor panel. Quote Link to comment Share on other sites More sharing options...
armlegx Posted March 29, 2023 Share Posted March 29, 2023 I am also having the sensor panel cpu usage and temperature sensors appear and disappear. The panel is also freezing at times, although the PC is not frozen. Quote Link to comment Share on other sites More sharing options...
Salsiccia Posted April 10, 2023 Share Posted April 10, 2023 On 3/29/2023 at 12:05 AM, DJTH said: I run the very latest Beta release of Windows 11. Windows 11 has been out of Beta and in Gold production for at least 1 year now. If you are still on Beta you should update to the real version. Quote Link to comment Share on other sites More sharing options...
