Caterpillar777 Posted April 5, 2023 Posted April 5, 2023 I just wanted to know if a tab feature is planned (or maybe already available) for the sensor panel or if it is impossible due to the rendering of the panel itself? And with tabs I mean exactly that. Just a little image/label to click on, showing you another page with the same dimensions (new 'canvas') or another sensor panel profile screen already set up. So basically just different tabs to click through. The reason for me asking is I would like to add additional info on not so important stuff but not on my minimalistic main sensor panel screen. Besides I play with the thought of adding multiple tabs for different hardware (e.g. CPU-tab, GPU-tab, Drive-tab, Traffic-tab, and so on). Quote
Caterpillar777 Posted April 15, 2023 Author Posted April 15, 2023 Ok I guess the support for the program is over. Time to look for alternatives then. For anyone interested, I found this handy tool for Windows, which already supports multiple profiles. https://apps.microsoft.com/store/detail/infopanel/XPFP7C8H5446ZD Quote
