Sensorpanel disappears when changing Primary Monitors
Hello!
I am using 4 monitors, one 27", 21", 34" and on the last, 7", the Sensor Panel is displayed. Everything works fine until I change primary monitors (I have to do this or otherwise certain applications won't open on the correct monitor).
When the primary monitor is changed, the Sensor Panel disappears and I essentially can't find it anywhere. I have it on "locked position" but it still happens.
I tried to arrange monitors differently in the windows config as I read the Sensor Panel uses the top right as 0,0 .. but still the issue remains.
When I switch the primary monitor back to the original the Sensor Panel reappears exactly where it should.
Thanks for your help!
