Hi,
when I use Runtime (German Laufzeit) it does not show the correct time in my sensor panel. I am not sure which time it uses here?
For example just now it showed 10:44:09 in Sensor Panel. But in Aida Statistics it showed correctly 11min 26 sec. And there is also an Image what Sensor Type I use here: "Laufzeit".
How to fix to show the correct Runtime in my Sensor Panel?
Thanks!
