Jean Augusto Posted June 20, 2023 Posted June 20, 2023 Hi guys, Can you share your rslcd themes for lcd 2.1" 480x480 Aio pump? thanks Quote
JunCLJ Posted July 30, 2023 Posted July 30, 2023 Use sensor panel, set 480 x 480 then click reset position. Click OK to quit AIDA64 Preferences. Right Click on the sensor panel then select SensorPanel Manager. Import this file then drag this sensor panel to your second monitor (the AIO pump screen). You need to install MSI Afterburner to enable the framerate in the monitoring settings in order to shows that FPS. 480x480 scale100.sensorpanelFetching info... 1 Quote
