Alerting system doesn't play selected sounds when events should trigger them
Hi all! Maybe someone here can guide me to check out something I might have missed. I'm setting one alert that makes a small chirping sound if my CPU Diode reaches a certain temp. I ran a stress test to hit that temp and no sound was made.
I played the file directly on Windows Media Player to make sure that was good, and it was.
Attached is a screenshot of how I currently have the software set up.
Thank you!
