I signed up for this forum to look for, and download 1024x600 sensor panels, but I see that almost all downloads are unavailable! Can someone explain why that is? I bought a 7 inch mini display just for this purpose, and now It's very hard to find any panels to use on it!
Thanks!
We have a limited amount of storage to keep all our files available. At times we need to remove older ones so we can post newer. If there is a specific file you would like, PM the creator and ask if they can make it available for you.
Yes, did search for panels that have the resolution of my mini monitor, although I found a few, there aren't many. I have contacted a couple of creators for their panels.
  • Thanks 1
On 26/08/2023 at 01:41, AryaHifi said:
Sim, procurei painéis que tenham a resolução do meu mini monitor, embora tenha encontrado alguns, não são muitos. Entrei em contato com alguns criadores para seus painéis.
Também estou procurando e não encontro
