JohnHagen Posted December 29, 2023 Posted December 29, 2023 I have multiple drives of the same model number, and multiple drives of another model number. When I go to set something like the Temperature display, I don't know which drive is which without a serial number. I have to run tests installing/removing drives to determine which is which. By adding the serial numbers to the drive model numbers when listing the drives in the Sensor panel, it would help immensely. See attached for what I believe would be helpful for those of use using multiple drives of the same model. Thanks for the consideration! John Quote
