I bought another 2 pairs RAM (CMWX8GD3600C18W2D). But when i open Dota or The Crew after of couple minutes (20-30 minutes)its dropping down.
Memtest showing errors on Test 8. I checked last ones serials on google its showing LPX module. Please help me seller wont return or refund me.
Field    Value
Memory Module Properties
Module Name    Corsair CMW16GX4M2D3600C18
Serial Number    None
Module Size    8 GB (1 rank, 16 banks)
Module Type    Unbuffered DIMM
Memory Type    DDR4 SDRAM
Memory Speed (XMP)    DDR4-3600 (1800 MHz)
Memory Speed    DDR4-2133 (1066 MHz)
Module Width    64 bit
Module Voltage (XMP)    1.35 V
Module Voltage    1.2 V
Error Detection Method    None
DRAM Manufacturer    Nanya
DRAM Stepping    00h
SDRAM Die Count    1
Memory Timings
@ 1798 MHz (XMP)    24-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    23-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    22-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    21-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    20-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    19-22-22-42  (CL-RCD-RP-RAS)
@ 1798 MHz (XMP)    18-22-22-42  (CL-RCD-RP-RAS)
@ 1700 MHz (XMP)    17-21-21-40  (CL-RCD-RP-RAS)
@ 1600 MHz (XMP)    16-20-20-38  (CL-RCD-RP-RAS)
@ 1500 MHz (XMP)    15-19-19-35  (CL-RCD-RP-RAS)
@ 1400 MHz (XMP)    14-18-18-33  (CL-RCD-RP-RAS)
@ 1300 MHz (XMP)    13-16-16-31  (CL-RCD-RP-RAS)
@ 1200 MHz (XMP)    12-15-15-28  (CL-RCD-RP-RAS)
@ 1100 MHz (XMP)    11-14-14-26  (CL-RCD-RP-RAS)
@ 1000 MHz (XMP)    10-13-13-24  (CL-RCD-RP-RAS)
@ 900 MHz (XMP)    9-12-12-21  (CL-RCD-RP-RAS)
@ 800 MHz (XMP)    8-10-10-19  (CL-RCD-RP-RAS)
@ 700 MHz (XMP)    7-9-9-17  (CL-RCD-RP-RAS)
@ 1066 MHz    24-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    23-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    22-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    21-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    20-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    19-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    18-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    17-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    16-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1066 MHz    15-15-15-36  (CL-RCD-RP-RAS) / 50-374-278-171-6-4-6-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 1037 MHz    14-14-14-35  (CL-RCD-RP-RAS) / 49-363-270-166-6-4-6-22  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 962 MHz    13-13-13-32  (CL-RCD-RP-RAS) / 45-338-251-155-6-4-6-21  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 888 MHz    12-12-12-30  (CL-RCD-RP-RAS) / 42-312-232-143-5-4-5-19  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 814 MHz    11-11-11-27  (CL-RCD-RP-RAS) / 38-286-212-131-5-4-5-18  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 740 MHz    10-10-10-25  (CL-RCD-RP-RAS) / 35-260-193-119-4-3-4-16  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 666 MHz    9-9-9-22  (CL-RCD-RP-RAS) / 31-234-174-107-4-3-4-14  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 592 MHz    8-8-8-20  (CL-RCD-RP-RAS) / 28-208-155-95-4-3-4-13  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
@ 518 MHz    7-7-7-18  (CL-RCD-RP-RAS) / 25-182-135-83-3-2-3-11  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-CCDL-FAW)
Extreme Memory Profile v2.0
Profile Name    Enthusiast (Certified)
Memory Speed    DDR4-3600 (1800 MHz)
Voltage    1.35 V
Recommended DIMMs Per Channel    1
@ 1798 MHz    24-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    23-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    22-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    21-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    20-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    19-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1798 MHz    18-22-22-42  (CL-RCD-RP-RAS) / 64-630-468-288-10-8-40  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1700 MHz    17-21-21-40  (CL-RCD-RP-RAS) / 61-596-443-273-10-7-38  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1600 MHz    16-20-20-38  (CL-RCD-RP-RAS) / 57-561-417-257-9-7-36  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1500 MHz    15-19-19-35  (CL-RCD-RP-RAS) / 54-526-391-241-9-6-34  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1400 MHz    14-18-18-33  (CL-RCD-RP-RAS) / 50-491-365-225-8-6-31  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1300 MHz    13-16-16-31  (CL-RCD-RP-RAS) / 47-456-339-209-8-6-29  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1200 MHz    12-15-15-28  (CL-RCD-RP-RAS) / 43-421-313-193-7-5-27  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1100 MHz    11-14-14-26  (CL-RCD-RP-RAS) / 40-386-287-177-7-5-25  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 1000 MHz    10-13-13-24  (CL-RCD-RP-RAS) / 36-351-261-161-6-4-23  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 900 MHz    9-12-12-21  (CL-RCD-RP-RAS) / 33-316-235-145-5-4-20  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 800 MHz    8-10-10-19  (CL-RCD-RP-RAS) / 29-281-209-129-5-4-18  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
@ 700 MHz    7-9-9-17  (CL-RCD-RP-RAS) / 25-246-183-113-4-3-16  (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW)
Motherboard:
Field    Value
Module Name    Corsair CMWX8GD3600C18W2D
Serial Number    None
Module Width    64 bit
DRAM Manufacturer    Samsung
DRAM Stepping    00h
SDRAM Die Count    1
Memory Timings
Voltage    1.35 V
Memory Module Features
Monolithic DRAM Device    Yes
Thermal Sensor    Present
Memory Module Manufacturer
Company Name    Corsair Inc.
Product Information   https://www.corsair.com/ww/en/Categories/Products/Memory/c/Cor_Products_Memory
Field    Value
Motherboard Properties
Motherboard ID    <DMI>
Motherboard Name    Asus TUF Gaming B550M-Plus WiFi II
Front Side Bus Properties
Bus Type    AMD K19.5
Real Clock    100 MHz
Effective Clock    100 MHz
North Bridge Clock    1802 MHz
Memory Bus Properties
Bus Type    Dual DDR4 SDRAM
Bus Width    128-bit
DRAM:FSB Ratio    54:3
Real Clock    1802 MHz (DDR)
Effective Clock    3604 MHz
Bandwidth    57665 MB/s
Motherboard Physical Info
CPU Sockets/Slots    1 Socket AM4
Expansion Slots    1 PCI-E x1, 2 PCI-E x16, 2 M.2
RAM Slots    4 DDR4 DIMM
Integrated Devices    Audio, Video, 2.5GbE LAN, WiFi
Form Factor    Micro ATX
Motherboard Size    240 mm x 240 mm
Motherboard Chipset    B550
Motherboard Manufacturer
Company Name    ASUSTeK Computer Inc.
Product Information   https://www.asus.com/Motherboards
BIOS Download   https://www.asus.com/support
Driver Update   http://www.aida64.com/goto/?p=drvupdates
BIOS Upgrades   http://www.aida64.com/goto/?p=biosupdates
Field    Value
CPU Properties
CPU Type    HexaCore AMD Ryzen 5 5600G, 4455 MHz (44.5 x 100)
CPU Alias    Cezanne
CPU Stepping    CZN-A0
Instruction Set    x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, AVX, AVX2, FMA, AES, SHA
Min / Max CPU Multiplier    14x / 39x
Engineering Sample    No
L1 Code Cache    32 KB per core
L1 Data Cache    32 KB per core
L2 Cache    512 KB per core  (On-Die, ECC, Full-Speed)
L3 Cache    16 MB
CPU Physical Info
Package Type    1331 Pin uOPGA
Package Size    40 mm x 40 mm
Transistors    10700 million
Process Technology    7 nm CMOS, Cu
Die Size    180 mm2
Core Voltage    0.912 - 1.350 V
Typical Power    65 W
CPU Manufacturer
Company Name    Advanced Micro Devices, Inc.
Product Information    https://www.amd.com/en/products/processors-desktop
Multi CPU
CPU #1    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #2    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #3    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #4    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #5    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #6    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #7    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #8    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #9    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #10    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #11    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU #12    AMD Ryzen 5 5600G with Radeon Graphics, 3900 MHz
CPU Utilization
CPU #1 / Core #1 / SMT Unit #1    7%
CPU #1 / Core #1 / SMT Unit #2    0%
CPU #1 / Core #2 / SMT Unit #1    3%
CPU #1 / Core #2 / SMT Unit #2    0%
CPU #1 / Core #3 / SMT Unit #1    0%
CPU #1 / Core #3 / SMT Unit #2    0%
CPU #1 / Core #4 / SMT Unit #1    0%
CPU #1 / Core #4 / SMT Unit #2    0%
CPU #1 / Core #5 / SMT Unit #1    0%
CPU #1 / Core #5 / SMT Unit #2    0%
CPU #1 / Core #6 / SMT Unit #1    0%
CPU #1 / Core #6 / SMT Unit #2    0%
Field    Value
CPU Properties
CPU Alias    Cezanne
CPU Stepping    CZN-A0
L3 Cache    16 MB
CPU Physical Info
Die Size    180 mm2
Typical Power    65 W
CPU Manufacturer
Multi CPU
CPU Utilization
