how to get rid of "right-click on the panel to add or edit sensorpanel items"???
Posted (edited)
Update: i'm an idiot. I figured it out......
how do i get rid of the "right-click on the panel to add or edit sensorpanel items" text on the display? i can't figure it out. i have the sensor panel set up the way i want it, but i can't get rid of that text. thanks in advance and ignore my stupidity if it's a simple solution that i am overlooking.
Edited by hntr83
I figured out my issue
