ldwilliams.uk Posted March 11, 2024 Posted March 11, 2024 Hi, I am looking to get the Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal https://shop.alphacool.com/en/shop/controllers-and-sensors/flow-sensor/17558-alphacool-es-flow-and-temperature-indicator-highflow-with-rpm-signal It has a conversion table for RPM to litres per hour which should be simple enough I would have thought, but the conversion ratio looks to change for each rpm given? How do I create an offset (think thats what is needed) and what would the offest be please anyone? Thanks Quote
ldwilliams.uk Posted March 12, 2024 Author Posted March 12, 2024 I think that the ratio is 0.18 and the offset is -10 ? Quote
ldwilliams.uk Posted March 12, 2024 Author Posted March 12, 2024 This bring results of Actual l/hr Reported l/hr 40 48.86 50 56.42 60 62.72 70 70.82 80 78.74 90 81.8 100 90.8 110 105.2 120 116 130 122.66 140 130.94 150 143 160 162.8 170 176.12 180 181.52 190 189.8 200 204.56 210 211.04 220 219.5 230 227.96 240 241.64 250 247.4 260 255.86 270 270.8 280 279.44 290 285.2 300 293.3 Quote
