Armand28 Posted March 26, 2024 Posted March 26, 2024 EDIT: The old monitor still had a program running in the background, removed it and rebooted and things are running OK now! I think this is resolved. Installed AIDA64, entered key. Rebooted. No CPU temp. Installed latest beta version of Aida64, rebooted, no CPU. Went into settings > Stability, checked every ASUS checkmark and EC Bank Switching, rebooted, still no CPU temp. Ran as administrator, still no CPU temp. I'm getting CPU temp just fine on every other application that shows CPU temps, just not AIDA64. Also not getting voltage and others, so something is off. What should I try next? Here's the dump: Sensor Properties Sensor Type HDD, Hydro Pt GPU Sensor Type Driver (NV-DRV) Temperatures Temperature #1 (Hydro Pt) 32 °C GPU 41 °C GPU Hotspot 52 °C GPU Memory 46 °C AGAMMIXS70B-2T-CS 41 °C / 32 °C Corsair MP600 PRO XT 27 °C 0 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ROG Strix Z690-F Gaming WiFi Motherboard Chipset : Intel Alder Point-S Z690, Intel Alder Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG STRIX Z690-F GAMING WIFI DMI MB Version : Rev 1.xx DMI MB Serial : 211296037302505 DMI SYS Manufacturer: iBUYPOWER DMI SYS Product : INTEL DMI SYS Version : System Version DMI SYS Serial : 91DC4E5BD1FDA733 DMI BIOS Version : 3302 ------[ PCI Devices ]------ ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0000h (0000h / 0000h) Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ========================================================================== ------[ 0 SMBuses detected ]------ EDIT: The old monitor still had a program running in the background, removed it and rebooted and things are running OK now! Quote
