Ronald Tyler Posted March 28, 2024 Posted March 28, 2024 I have been using a Raspberry PI4 for a remote PC Sensor on my network to monitor my PC Temps and so on. This was working great until I did a Windows Refresh and had to reinstall all my software, including Aida64 (latest Version) However, after creating a new Screen for my Pi and updating the PI configuration to boot on to the sensor and open Chrome / kill the mouse cursor I get a blank screen. I am not a Linux / programing boffin (can follow instructions and that is about it ) Looking for any help I following this tutorial on Youtube and it worked well until the refresh I have followed the instructions to a T with the following commends implemented sudo apt-get install unclutter sudo nano /etc/xdg/lxsession/LXDE-pi/autostart Added the following to the autostart: xset s 0 xset -dpms /usr/bin/chromium-browser --kiosk --disable-restore-session-state --ignore-certificate-errors http://(my network ip address for PC to monitor) Any tips to help - PI is new and works until the above is added - can't seem to find any new instructions on what to place into the AutoStart Config file to get it to seek the data from the LCD panel data that Aida64 is broadcasting Quote
