AK_Freaky Posted May 25, 2024 Posted May 25, 2024 CPU I9-14900K GPU 4070Ti RAM Gskill DDR5 7600 4x16 MB Asus Z790-E WIFI II SDD Crucial T700 2TB M2 Gen5 Asus Ryujin III 360 AIO cooler Hi Need some help! Not a CPU expert by any means...My CPU stress test runs fine, stable at 72C with no throttling, but the FPU and MEM fails almost immediately due to heat and CPU shows the same 72C. I have my RAM clock set to 6800, thought that was the issue, but not sure. I found the issue with the system as it currently crashes TradeStation when running chart optimizations...lot of calculations. Any advice would be greatly appreciated. Thanks Quote
AK_Freaky Posted May 25, 2024 Author Posted May 25, 2024 I just saw another similar post from a couple months ago regarding "Asus Performance Enhancement 3.0" so going to try to find that and see what happens... Quote
AK_Freaky Posted May 26, 2024 Author Posted May 26, 2024 For others reference, I went back to default and turned off Asus multi-core enhancement. This solved most of the issues I was able to clock up RAM again and seems to be testing fine now. Quote
