DL2K7 Posted July 16, 2024 Posted July 16, 2024 Hello dear team, I use the Aquacomputer “high flow next” and have also activated the “Aquaero Sensor” under “Stability”. I can also display the flow rate on the sensor panel. However, the “Water quality” is also displayed under “Computer > Sensors”. I would also like to display this on the sensor panel. How do I do this and is it currently even possible? Kind regards Alex ------------------------------------ Deutsch Hallo liebes Team, Ich nutze den Aqua Computer „High Flow Next“ und habe unter „Stabilität“ auch den „Aquaero Sensor“ aktiviert. Die Durchflussrate kann ich mir auch auf dem Sensor Panel anzeigen lassen. Aber die „Wasserqualität“ kann ich nur unter „Computer > Sensoren“ einsehen. Ich würde diese gerne auch auf dem Sensor Panel anzeigen lassen. Wie mache ich das und geht das überhaupt zur Zeit? Liebe Grüße Alex Quote
DL2K7 Posted September 1, 2024 Author Posted September 1, 2024 Doesn't a team member have an answer for me? Quote
maximus888888 Posted August 18, 2025 Posted August 18, 2025 Hi! sorry to resurrect, but I also have the same issue! Does anyone have insight in this problem? i did find a post here Quote
Fiery Posted August 23, 2025 Posted August 23, 2025 On 8/18/2025 at 7:37 PM, maximus888888 said: Hi! sorry to resurrect, but I also have the same issue! Does anyone have insight in this problem? i did find a post here The status of such readings is still the same. Quote
n00bftw1989 Posted 23 hours ago Posted 23 hours ago I have a custom PowerShell script that will add Conductivity and Water Quality and just about anything else out of Aqua Computer's software and add it into AIDA64 so you can apply it to your LCD temp display. Quote
