Scooby4ever Posted August 3, 2024 Posted August 3, 2024 Hi Fiery I have a odd problem on my sensorpanel i created for my system. The wifi info like download or upload and wifi signal is not showing on sensor panel after i boot-up windows 11 64bit I have motherboard Asus ROG Strix Z790-A Gaming WiFi II (bios 1402) note it have been the same on all bios versions i had on this board. I have the lastes Aida64 release. Only thing that helps is if i start youtube or any other program that checks internet and restart Aida64 at the same time. I havent found any solution is there way to tell Aida to force them to be visible in sensorpanel. Note they are shown in main prg aida64 if i check through info Cheers for any help. And thx for still updating Aida. Quote
Scooby4ever Posted August 19, 2024 Author Posted August 19, 2024 Now using bios 1503 with latest microcode. I Still have same issue. Below is my PC Setup if that speeds up things: Intel Core i9-14900K (Intels performance settings in bios) Corsair iCUE Link H150i LCD AIO / 360mm Radiator (Using latest ICUE software) Asus ROG Strix Z790-A Gaming WiFi II (Latest bios 1503) DOMINATOR TITANIUM RGB 64GB 6600Mhz (2x32GB) DDR5 DRAM ASUS ROG Strix GeForce RTX 4090 White Edition OC Windows 11 64bit Iam using Phantek display to show all hardware info, temps etc (( Is there a way to force or a keypress to restart sensors on display? )) Quote
Scooby4ever Posted October 29, 2024 Author Posted October 29, 2024 A reply is better than none. 🤐🙄 Quote
