Powershell script to move sensorpanel to specific monitor
I got sick of the Sensorpanel opening on the wrong monitor, even with the built in pin feature, that I decided to try and write a powershell script to avoid the issue.
This is written with a lot of help from chatgpt.
I have attached the powershell script. It should be edited at the top with your desired screen width and height.
The script will look through your connected monitors and find one that matches your desired resolution.
It will then move and resize your panel to that monitor.
If you have more than one monitor with the same resolution as your desired res, then I don't know... I have not taken that into account.
If the sensorpanel hasn't started yet, it will loop until it finds it.
NOTE: It requires to be run as administrator to work.
It can be run on boot with task scheduler. This is my setup:
The argument should be: /c start /min "" powershell -WindowStyle Hidden -ExecutionPolicy Bypass -File "C:\SensorPanelMoverLoop.ps1"
<--- Edit to match the path to where you saved the script.
The reason we start it this way through CMD is to avoid the powershell window to flash open on boot.
The rest can be left default.
Hopefully this helps someone else besides me!
  • 5 months later...
