New ElecLab 11.26" 440x1920 display, HDMI input or connect to Raspberry Pi to make a wireless Aida64 secondary display.
The new 11.26" 440x1920 is natively portrait, but can be set to landscape using display rotation. A Raspberry Pi can be mounted on the rear of the display, which can be turned into an Aida64 wireless display with a simple setup.
Of course, the display shell is not provided, only the STL file can be directly used to make the shell using a 3D printer, and spray painted with your favorite color.
7.84"/8.8"/11.26" display link:
https://www.amazon.com/ElecLab-400x1280 ... B0CSVMJK8Z
https://www.amazon.com/ElecLab-480x1920 ... B0CSVB4NPZ
https://www.amazon.com/ElecLab-440x1920 ... B0CTMYWPSP
7.84” 400x1280/ 8.8" 480x1920/ 11.26" 440x1920 stl files:
https://github.com/eleclab-rpi/7.84_8.8_11.26INCH_HDMI
I had a broken 10" LED clock, so I made a clock with an 11.26 Inch 440x1920 HDMI Screen. I used pygame to set up two alarms, one for the table to remind the kids that it's time to go to school, and the other for easy viewing of the clock. I gave it three skins and an old-fashioned clock ticking sound, and of course a warning sound that can clearly serve as a reminder.
The shell has been printed and assembled. The Raspberry Pi 3 is running Bookworm 64. The speed is a bit slow, but it is just enough to run this simple application. For testing, I set the hourly time and the school reminder.
The next step is to display the weather.
