How to Enable case fans monitoring for Lian Li L-Connect 3 software?
Hello
Is there a way to enable case fans speed monitoring if using Lian Li Lconnect 3 software?I have connected my Lian LI Uni Hub to my MB only with ARGB cable as L3 connect lacks the future to use colors to display temerature readings. Fan control is not connected from hub to MB as MB overtakes L3 software and the fans at lowest settings 50%  are spinning at 1.2k rpm which is loud( using 4x lian li inf 140 fans. Dus for fan speed controll i use L3 software set to quiet mode that spins about 600 rpm and gradually adjust with temperature on quiet mode in accordance with  graph.
I have a 2nd issue aswell for sensor not displaying FPS when set to RTSS FPS.I have disabled Nvidia fps display and using steam, but i would like to have it displayed on my monitoring LCD.
Anyone can help?
Regards and thx in advence
  On 10/29/2024 at 10:56 PM, Letsu said:
Hello
Anyone can help?
Expand
As far as I know, AIDA64 is unable to support Lian Li fans. AIDA64 can detect a single Lian Li fan but not the daisy chain fan. You can read my post from the Hardware Monitoring forum.
You can set your fan speed from the BIOS setting.
As for the FPS, you need to install the Guru3D RTSS Rivatuner Statistics Server.
