unable to right click to make any changes to sensor panel when using external panel hdmi screen
Posted (edited)
I am unable to Login to the forum the /login page is offline, but my issue is the sensor panel i use 1920x480 when I wanted to make changes or modify anything in the panel i would right click on it and open a preference window, been so long since I made changes i can't remember exactly, but it wont do that any  more. ignores right click.  I can't even change my sensor panel any more. is this a recent bug, something wrong on my side. or has anyone else experienced this problem also. another thing i found interesting is each time I rebooted Aida 64 would say there is update available. I would run the update, restart the program. then it would say there is yet another update.
My biggest issue is i want to make sensor changes and the right click is broken.
thanks
I found there was a tic box in settings to allow "Context Menu" not sure how that was disabled but all good now
Edited by Dudleydogg
I believe i found issue
