Mapantz Posted July 5, 2025 Posted July 5, 2025 Hi I installed a new motherboard today. I had to change the NIC's in the LCD items to get them to show, as they changed numbers. All was good until I rebooted, and the NIC changed again. In fact, the NIC changes every time I start up the PC, or have to reboot. Any ideas on what might be happening? Regards. Quote
Dave59337 Posted July 8, 2025 Posted July 8, 2025 Had the same problem. It appears all possible NIC's show up and change numbers (NIC1, NIC2, NIC3, etc.) I would pick the used one while creating a sensor panel. A day or week later it would flatline on the sensor graph. I would have to change the number being used each time. Since they all were just hanging around on the motherboard, and only one was being used I disabled the others. Since I use ethernet cables, I disabled the wireless in CMOS. One computer has two ethernet inputs, so I disabled the one not plugged in. I can't remember what I did, but I had to change some setting in Bluetooth as well. I finally ended up with NIC1 and no others showing up. Haven't had issues after. Quote
Mapantz Posted July 17, 2025 Author Posted July 17, 2025 Sorr On 7/8/2025 at 6:22 AM, Dave59337 said: Had the same problem. It appears all possible NIC's show up and change numbers (NIC1, NIC2, NIC3, etc.) I would pick the used one while creating a sensor panel. A day or week later it would flatline on the sensor graph. I would have to change the number being used each time. Since they all were just hanging around on the motherboard, and only one was being used I disabled the others. Since I use ethernet cables, I disabled the wireless in CMOS. One computer has two ethernet inputs, so I disabled the one not plugged in. I can't remember what I did, but I had to change some setting in Bluetooth as well. I finally ended up with NIC1 and no others showing up. Haven't had issues after. Sorry for the late reply. Thank you for posting that.. This is a new motherboard, and I only just realised that 4 NIC's were enabled in the Windows settings. Ethernet, Wi-Fi 2, Wi-Fi 5 and Wi-Fi 6. I disabled the 3 Wi-Fi NIC's, as I don't use them. Only NIC1 shows - my Ethernet - and no more issues! Quote
