Winterfoot Posted August 4, 2025 Posted August 4, 2025 So, clearly made some mistakes when I built my rig. I'm using an MSI Z690 Unify-X Mobo, and utilized two Corsair Commander Core XT Hubs to control 10 fans. I have the CC hooked onto the Mobo using a JUSB port instead of the JCORSAIR port, although I've been told explicitly by MSI this makes no difference and they do not support Corsair products. I cannot collect the fan RPM data in Aida 64, but it does show up in HWInfo64. I did manage to get away from the iCue software and now use FanControl along with the Aida64 and Corsair plugins, which allow me to see sensor data and fan RPM speed. This seems a positive step since iCue causes known conflicts with other programs; however, I still can't get the fan RPMs to show up on my Aida sensor panel. My thought process was to get rid of iCue, get another program reading and controlling the RPM data, then using Aida to share the info from the control program, but I can't seem to figure out that final step. Is there a way I can capture that RPM data on my sensor panel, or am I looking at swapping hubs, or doing direct connections (with splitters) to the MOBO so I can collect that data? Thanks in advance Quote
