mido1112005 Posted October 2, 2025 Posted October 2, 2025 Introduction Sensor Panel Resizer is a simple Python-based tool that allows you to resize your AIDA64 Sensor Panel files (.spzip). It is useful if you want to adapt your existing sensor panel designs to different screen resolutions without recreating everything from scratch. Requirements Python 3.10+ (Download: Python.org ) Required libraries will be installed automatically when running the script. Usage Export your Sensor Panel from AIDA64 in .spzip format. Open the program (main.py). Load the exported file (.spzip). Enter your desired resolution in the fields: Target Width Target Height Save the resized file. Go back to AIDA64 and Import the saved .spzip file. That’s it! Your sensor panel will now fit the new screen resolution Sensor Panel resizer.zip 2 Quote
MaRCoRe Posted December 24, 2025 Posted December 24, 2025 hello, I tried to resize some sensor panels for a 1024x600 screen, the sensor panel is resized but all the information inside remains all out of place. thanks Quote
