PaulieZero Posted November 19 Posted November 19 Thank you in advance for your input and assistance! I have an Asrock Taichi AMD Radeon RX 9070 XT graphics card, and I'm having a problem where I can't seem to get the temperature, voltage, or clock sensors to read in AIDA64. The GPU itself is visible in AIDA64\Display\GPU In Sensors, it reads as "GPU Sensor Type: Diode (ATI-Diode)" and it shows a single incorrect temperature sensor of "GPU Diode: -243 C". I am running Windows 11 24H2, AMD Adrenalin 25.9.2 (September 2025), AIDA64 Extreme v8.00.8000. I am hoping to avoid going up to newer versions of AMD Adrenalin because of a current known issue with HDMI 2.1 single loss which does unfortunately affect my monitor. I have tried reinstalling AIDA64, rebooting, and running as administrator. I can see basic information like clock speed and temperature in AMD Adrenalin, and all of the other expected sensors using a different monitoring product. I'm not sure what should be adjusted in AIDA64 to get the sensors to appear. Quote
PaulieZero Posted November 20 Author Posted November 20 Update: I reinstalled Windows and then reinstalled the software. This appears to have resolved the issue. I don't know what went wrong last time. Quote
