OneRound Posted February 1 Posted February 1 I created a "n-state" gauge with 26 steps from 0 to 25. The gauge is attached to CPU temperature. I also have a simple sensor set to CPU temperature and that temp reads the same as my motherboard is reporting, so Aida does read the value correctly. I set the min-max values of the gauge to 20 and 95. 20 being room temp and 95 as hot as I want to see until I understand my new system. As I understood it, 95-20 means a 75 degrees range. And with 25 steps in the 75 degree range each 3 degrees change should move the gauge one more step on the display. So, with a temp of 40 degrees, I assumed I would get either 6 or 7 steps out of the 25 displayed on the gauge. But I'm getting about 14. I will include a screen snip below. Hopefully someone can give me some insight into this issue. Quote
OneRound Posted February 1 Author Posted February 1 Never mind, I deleted all the entries and reentered them, and it now seems to work OK. Quote
