Keizer Posted October 13, 2020 Posted October 13, 2020 Greetings fellow members! I just built a new system and use a Corsair iCUE H150i Elite Capellix CPU Cooler. The pump RPM shows up just fine in AIDA 64 but the three radiator fans are MIA. In AIDA 64 I have both Asetek LC sensor support and Corsair link sensor support checked. I've even stopped the Icue software from starting with windows to eliminate any conflict with AIDA 64.....but no success. Is the problem from having the three cooling fans connected to the iCue commander core instead of directly to the motherboard? Thanks!! Quote
Keizer Posted October 13, 2020 Author Posted October 13, 2020 I ended up disconnecting the fans from the commander core and connected them directly to my mobo. Now they show up in AIDA 64. Now I can set up a fan curve in the bios and still control my RGB lighting from the commander core. Quote
