Hi all im new and joined in hope someone can help me!
I have just today discovered and installed AIDA64 and have bought the extreme edition key! I have made up a new pc and this is the first time i have installed a 5'' touch screen (elecrow) to my build and i wondered is there anyone who can make me up a fancy sensor panel in the  800x480 resolution so i can just import the file?
system specs are!
thermaltake tower 900
msi mpg z490 gaming carbon
core i9 10900k cpu
evga gtx 1080ti ftw 3 (pre order waiting on a rtx3090)
corsair vengeance pro rgb 128gb 3200
2x m2 1tb ssd
4x 1tb ssd
superflower 2000w platinum psu
2x ek 560mm rads
2x ek -quantum kinetic 300 d5's
12x rgb 140mm fans
MANY MANY THANKS in advance
  • 3 weeks later...
dont know if people can create files for another and it import and works but if its any help I just did a monitoring dashboard in about an hour its pretty easy to do once you get into it
