Hello!
I founded strange behaviour in AIDA64 Cache & Memory Benchmark. L3 cache bandwidth on processor look lower then it's actually is. It's don't matter which settings i use in BIOS (even optimized default). Here is details:
System spec:
Hardware:
CPU: AMD Ryzen 7 5800X (2049SUS);
Cooler: Phanteks PH-TC14PE;
Tim: IC Graphite Thermal Pad;
MB: GIGABYTE B450M DS3H v2 Rev. 1.0 (BIOS: F60h, AGESA Combo V2 1.2.0.0, SMU 56.45.00);
RAM: 2x 8GB Team Group Dark Pro DDR4-3600 (16-16-16-16-36-1T, FCLK=1800MHz);
Software:
AIDA64 v6.32.5600
AMD Chipset Driver v2.13.27.501
So, here is two tests (low L3 cache bandwidth and normal):
LOW
I may click on each L3 box (Read\Write\Copy), but it never go above ~350 GB\s. At this stage problem was PBO setting in AMD CBS (in BIOS). After i disable PBO in AMD CBS and set it on Auto in AMD Overclocking (in BIOS) - i got ~400 GB\s. At this point CPU got correct all it's limits (PPT\TDC\EDC).
Normal
Now i got this. How? As you may guess - i set fixed frequency on all cores - 4425 MHz. It's only one setting from BIOS (well... actually voltage too, but anyway).
Question: Why AIDA64 Cache & Memory Benchmark can't meassure normal bandwidth with auto setting on cores frequency?
My guess is next: Cores are in "sleep" (i know it for sure, since i run AIDA64 with opened Ryzen Master window) and benchmark end faster then cores wake up. When used fixed cores frequency - benchmark sent data on "ready" core and data more correct.
