Iosif Karaioannoglou Posted June 27, 2021 Posted June 27, 2021 a) Can you make the date and time modules get the values from the client? My PC goes into standby mode and I use the remote website in my living room and the time sensor stops working when the PC is offline. b) Can you add a slideshow option on the image display type? As I said I use my android phone as a remote monitor in my living room so I'd love it if I get to add a bunch of photos in a folder so that they rotate. I do that now using multiple pages but it's limited. c) Can you add a parameter that hides a control when the value is not between a min and max? For example I've got the RTSS fps showing 0 all the time while not gaming d) Is there perhaps a rest API I can use so I can do all the above myself? Quote
