haze_1986 Posted August 27, 2021 Posted August 27, 2021 Hi All, I have just started using AIDA64 for monitoring. I realise that there is a tendency for the fans to rev up to max or being turned off. Once this happens the RPM will get stuck at either max or 0 until I restart the computer. I have read some hacks such as Dell SMI sensor support, Embedded control EC support and also Asus WMI sensor support. Now I have all 3 disabled and I am still having this problem. Is there a safe mode I can try so I can still use AIDA64? Or what else should I turn off under stability options? I am using Asus B350-f with 3700x Quote
