Hi,
I am using a 7 inch 1920x1080 panel exclusively for the sensor panel. The issue is that the sensor panel will automatically resize itself randomly after booting. It doesn't happen all the time but is often enough to be an issue. Importing the saved ".sensorpanel" file doesn't change anything either; also changing the sensor panel size to 1920x1080 from preferences does fix the size but the position of all the gauges, graphs, bars etc. still remain misaligned and needs to be fixed manually every time this glitch happens please help.
P.S: This glitch happens even after I have the lock sensor panel size and position options turned on.
