frankie53 Posted February 27, 2022 Posted February 27, 2022 Does anyone know how to prevent AIDA64 shutting down and logging stopping after approximately 20 minutes? Quote
James Kyle Smith Posted August 19, 2022 Posted August 19, 2022 Have you (or any one else) figured out a solution to this? I am facing the same problem where logging to CSVs will just stop for no reason. I'll run a stress test and get a crash 30 minutes later but then when I look at the logs, I will see that logging stopped 20 minutes prior to the crash so I am not able to see what's going on. Quote
James Kyle Smith Posted August 22, 2022 Posted August 22, 2022 I think I figured it out. There seems to be a bug where if you open the log as it's being written to, Aida64 will stop writing to the log. My guess is an exception occurs from not being allowed to write to the file as it's open in another application. A temporary workaround is to copy the log file before reading from it. But, this is not a long-term fix because other processes may try to open the file for some reason (for example, backup software). Quote
