Ryzen 3 3200g wrong core voltage?
NotTooLazy
Hello, i'm running a Ryzen 3 3200g with PBO disabled, and it seems that in AIDA64 voltage readout whenever voltage goes over 1.0v it just jumps to exactly 1.400v, meanwhile HWinfo and CPU-Z both tell me it maxes out at 1.2XXv, never reaching 1.3v. I'm using version 6.60.5939 beta, the latest stable release does the same. No difference between the installer and .zip versions.
I'm not running any form of overclock, and again PBO is disabled. Voltage is set to auto in the BIOS.
My motherboard is MSI A320M-A Pro Max, if that helps.
  • NotTooLazy changed the title to Ryzen 3 3200g wrong core voltage?
