Missing Gigabyte EC sensor, Aorus Master X570S Rev 1.0
lmfs42
A fan sensor seem to be missing for the Gigabyte Aorus Master X570S Rev 1.0. System fan 7 and 8 pump values are missing. HWiNFO detect the fans on "Gigabyte EC". See images below. AIDA64 version 6.70.0600 (registered).
I have noticed on my Gigabyte X570 Aorus Master motherboard and my Gigabyte Aorus GEForce RTX 3070 Ti Master video card I cannot monitor the GPU fan speeds, the GPU clock speed is only 1/3 of actual clock speed, I cannot monitor the GPU temp and as I've noticed in other forums I cannot monitor the pump speed from the motherboard.
There will probably be more but the only ones I would care to have are the ones mentioned above.
I appologize if the solution has already been posted but when I searched I did not see anything other than update to the latest beta which I have done.
TIA
  • 2 months later...
I can confirm that motherboards X570S Aorus Master Headers 7 and 8 cannot be monitored nor used as a sensor inputs for display panel as of now.
------[ Versions ]------
Program Version : AIDA64 Extreme v6.70.6000
BenchDLL Version: 4.5.868.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19044.1766 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : <DMI>
Motherboard Model   : Gigabyte X570S Aorus Master
Motherboard Chipset : AMD Bixby X570, AMD K19.2 FCH, AMD K19.2 IMC
DMI MB Manufacturer : Gigabyte Technology Co., Ltd.
DMI MB Product      : X570S AORUS MASTER
DMI MB Version      : Default string
DMI MB Serial       : Default string
DMI SYS Manufacturer: Gigabyte Technology Co., Ltd.
DMI SYS Product     : X570S AORUS MASTER
DMI SYS Version     : -CF
DMI SYS Serial      : Default string
DMI BIOS Version    : F4d
ITE SuperIO Port           = 2Eh
ITE SuperIO HWMonitor Port = 0A40h     (    0A40h /     0A60h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 8689h     (    8689h /     8695h)
ITE SuperIO Version        = 01h       (      01h /       01h)
Winbond SuperIO Port              = 00h
Winbond SuperIO Device ID         = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ LM78 ISA Sensor Device at 0A40 ]------
0000  13 10 00 80  DF FF 00 20  FF 98 48 40  30 FF 8A FF
0010  FF FF FF 77  C7 D0 C8 C8  FF 02 FF FF  FF FF FF FF
0020  61 A5 A7 A4  59 4B 71 8A  80 2F 20 2D  34 30 35 80
0030  FF 00 FF 00  FF 00 FF 00  FF 00 FF 00  FF 00 FF 00
0040  7F 7F 7F 7F  7F 7F 5F 40  AD 6A D4 00  00 00 00 00
0050  FF 18 7F 7F  7F 40 00 00  90 00 14 12  65 00 00 00
0060  00 14 41 42  04 01 00 C0  00 14 3C 00  0C 01 00 FF
0070  00 14 3C B2  00 01 00 2E  00 14 3C 7F  00 01 00 C8
0080  EC 00 FF FF  FF FF FF FF  00 00 00 00  00 56 00 D0
0090  00 00 00 00  FF 10 10 10  42 99 00 00  01 1E F2 2D
00A0  00 14 41 42  04 01 00 D0  7F 7F 96 80  00 00 0F 98
00B0  C2 CE 82 78  7F 7F 83 00  5F F0 80 2F  80 80 80 00
00C0  00 C0 00 04  01 01 10 10  10 10 10 10  10 10 10 10
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF 01
00F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 00
   0029 002A 002B
T:   47   32   45
T:   47   32   46
T:   47   32   46
T:   47   32   46
T:   47   32   46
T:   47   32   46
T:   47   32   45
T:   47   32   45
T:   47   32   46
T:   47   32   45
   0020 0021 0022 0023 0024 0025 0026 0027 0028
V:  77   A5   A7   A4   59   4B   71   8A   80   [ VID = 1.10000 V ]
V:  77   A5   A7   A4   59   4B   71   8A   80   [ VID = 1.00000 V ]
V:  5A   A5   A7   A5   5A   4B   71   8A   80   [ VID = 1.00000 V ]
------[ LM78 ISA Sensor Device at 0A60 ]------
0000  19 10 02 00  FF FF 00 00  00 80 48 00  30 EC E5 BC
0010  FF FF FF 77  C0 00 00 02  00 00 02 FF  FF FF 19 19
0020  A5 FF 56 05  A4 6D 80 9B  8B 35 21 2B  A1 FC 0C 9B
0040  7F 7F 7F 7F  7F 7F 5F 40  AD 6A D4 00  00 00 FF FF
0050  FF 38 7F 7F  7F 40 00 00  90 00 32 12  65 00 00 00
0060  00 14 41 99  1C 03 00 FF  00 14 41 99  1C 03 00 FF
0070  00 14 41 7F  1C 03 00 FF  FF FF FF 80  FF FF 0F FF
0080  FF FF 00 00  FF FF FF FF  00 00 00 00  00 B6 02 D9
0090  FF 00 00 00  FF 00 00 00  06 97 00 00  40 E6 C1 83
00A0  BA CF 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF 00 7F  43 4B 0F 00  00 FF FF FF
00C0  4C 4B 00 00  00 00 00 FF  FF FF FF FF  FF FF FF FF
00D0  83 A1 91 41  CE 25 D5 21  04 FF FF FF  FF FF FF FF
   0029 002A 002B
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
T:   53   33   43
V:  A5   FF   56   05   A4   6D   80   9B   8B   [ VID = 1.10000 V ]
V:  A5   FF   56   05   A4   6D   80   9B   8B   [ VID = 1.00000 V ]
V:  A4   FF   56   05   A4   6D   80   9B   8B   [ VID = 1.00000 V ]
V:  A4   FF   56   05   A4   6D   80   9B   8B   [ VID = 1.10000 V ]
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM2 at 0CD0 ]------
0000  05 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0050  00 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF 00 00  00 00 00 00
0090  00 00 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  00 FF 00 00  FF 00 00 FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 00  08 08 00 02
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM at 0CD6 ]------
0000  F7 0B 07 E3  02 04 01 00  14 05 1C 02  06 21 43 55
0010  74 00 50 01  16 00 20 00  42 86 64 A8  40 00 3C 00
0020  20 01 9C 01  A0 00 E0 00  55 00 10 00  80 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 08 01 00
0040  FF FF FF 00  00 00 00 88  21 2B 35 59  00 00 3F 49
0050  00 00 3E 3F  90 00 00 14  01 FF 15 44  00 06 00 00
0060  00 08 04 08  08 08 10 08  20 08 B2 00  FF FF BA 00
0070  01 1F 00 00  17 05 06 19  FF FF 00 00  FF FF E0 80
0080  00 00 26 00  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  01 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  F8 CE FF 00  00 00 00 00
00B0  00 20 84 02  00 00 80 05  88 00 28 00  02 00 52 C0
00C0  00 08 20 00  28 02 00 00  0C 40 28 00  DB B6 6D DB
00D0  00 F4 00 BF  00 00 00 00  00 00 11 00  00 00 00 00
00E0  D8 0C 00 00  03 00 01 00  04 00 00 01  15 16 0B 7F
00F0  9C 73 00 00  00 00 00 00  3F 00 F0 FE  00 00 00 00
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
isasensordump.txt
