Hello friend I'm finishing my secondary monitor screen with aida64
Weather forecast in sensor panel? its possible?
how to put
Thanks
  • Sensor Moderators
how to put
Thanks
Sorry but you can't.... You can use only sensors from the list
On 6/28/2022 at 1:32 AM, Ser4ph4 said:
how to put
Oh I have no idea unfortunately. But it’s just a second display, so if there’s an app that Displays readings, you can just drag it to the second display and you’re good.
21 horas atrás, sammyadam disse:
Ah não faço ideia infelizmente. Mas é apenas uma segunda tela, portanto, se houver um aplicativo que exibe leituras, basta arrastá-lo para a segunda tela e pronto.
I thought about that too, I'm researching about it, I also read about using the rainmeter
grateful friend
  • 4 weeks later...
Maybe u'll have to be creative :D
Give room on your sensor dedicated to a forecast app or widget and put it in front of aida at the size u decided (empty box)
OR, make ur sensor panel another size and let the rest for your app /widget
