Jay Dog 979 Posted July 6, 2022 Posted July 6, 2022 I got a custome made sensor panel and downloaded the .sensorpanel file as well as the needed fonts. I instaled and imported the file but it is way to big for my 1024x600 display. The resolution is set to 1024x600 in preferences and I've checked and double cheched that my display is in fact a 1024x600 display. It is set to the correct resolution in windows and the scale is set to 100% (recommend). This is the only option shown for scale. I can clearly see that it is way to big. It appears to be about 2560x1500. In addition to this, the gpu temp just displays N/A. Does anyone know what could be causing this and/or how to fix it? Please be aware that I am very new to aida64 but trying to learn. Thank you. Quote
Blackvoodoo Posted July 8, 2022 Posted July 8, 2022 I have the same problem. I have a 1920x480 display and every sensor panel I have tried here that is supposed to be for 1920x480 is way too big. No idea what I am doing wrong. Quote
Singhsta Posted July 30, 2022 Posted July 30, 2022 Similar issue. My screen is 1024X600 but when I import a sensor panel it changes to 1536X900 for some reason and everything is just misaligned. On Win 11. Any of you guys figured out a solution? Quote
